LG V60 Wont send text messages
ok so chrome works and i can pull up websites no problem. Ok so the green label messenger is the LG one and the Red one is google verizon messsenger plus...............now here is a issue, when i try to use the red google one it wont open at all it just does nothing, only the green one works but i think its the stock LG app and that was dissabled in 2024..........................something weird is going on............................i cant delete either one of them
Go to settings>connections>tap mobile data >APN tap then upper right corner tap 3 dots and tap reset APN
Hmmm
That should reset your sim if any issue on that end.
Does it give an error when trying to send?
uOttawaGrad_22
