Sim signal problem, how can I fix it?
  • Start date Start date
A
AC Question
sim signal problem
my samsung note 3 have problem .
its show no signal of sim mostly ...some time show but after that they will disappear ..
when i enable mobile data then sim signal will disappear ..
how i can overcome this problem?
Re: sim signal problem
Can I cut down the micro sim from my G3 to use in my v10? I thought the v10 took a micro sim, but turns out, it takes a nano sim...
Yes you can. Make sure to do it correctly or it won't work.
Ok cool...I watched some YouTube videos on how to do it, so I hope that is enough to get me through the process
Ok so cutting the micro sim into a nano sim was not hard @ all!!! Took less than 1 minute!!! Thx dpham00 , you is the man!!!
Jon OapostraphyBrien
