Skype Notification Sound (not working)
JDA54669
Active member
Aug 14, 2013
41
I used to get an audible alert when I received Skype messages. For some reason now I don't. After checking all of the settings I could think of, it appears that it is turned on.
Any ideas of how to fix this? Thanks
Have you tried rebooting?
Was the Skype app recently updated? If so, perhaps clearing the cache and/or clearing data for the app will work. If that doesn't help then uninstall and reinstall the app.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Just tried a complete uninstall and reinstall. Checked all settings, they look fine. No sound. And volume is cranked up.
Bummer.
Was the Skype app recently updated? Or did your phone get updated to KitKat (or something similar)?
When you changed the volume, did you press the gear icon and adjust ALL of the volume levels up?
I'm not even sure a Factory Reset will fix your problem but that's next on the troubleshooting list.
My nexus 7 has been on kitkat a long time now so that shouldn't be the issue... Just did a power off and on cycle, no luck. The visual notification light works fine. Other sounds are working fine
The Skype app was last updated about a month ago (May 20th) - has the problem been going on that long?
You could try rebooting into Recovery mode and clearing the system cache - it's unlikely to fix this problem but it won't hurt and it's quick to do.
Last of all is a Factory Reset...
That may have been when the problem started. I just got a kitkat update and it works now,
mechelle1368
