Skyrocket now officially supported by Cyanogenmod!
Do I need to install the AT&T radio package, or does CM9 have it?
I'm only asking because I don't see "4G" or "4GLTE" listed at the top like it used to... I see an "H" instead. It seems to be working okay, but I just want to make sure.
For the life of me I can't get CM9 to boot. Just stays stuck on the boot screen.
Jeez! Figures as soon as I type that it boots.
Happened to me as well.
Head on over to XDA and grab up the darkside super wipe and cache wipe. Put them on your external SD card and boot into CWM, flash both, then install CM9 - should work like a champ at that point.
I rooted and installed cyanogenmod last night. then today I go to install todays nightly and after booting into clockworkmod touch I get an error saying it can not mount the zip file. has anyone had this problem before. What can I do to update .
thanks
thanks
Did you do a backup and proper wipe first? It could be a bad download or copy. Try downloading it again and re copying it to your SD card.
I cannot do a backup. It sayws it cannot mouse the backup path. I think it is not seeing the external sdcard now for some reason.
It want read any of the zip files. I think the sdcard is not being mounted at all, I can not do a backup , it says it cannot mount the backup point. I tried to repair permisions and that did not work. I not sure what to do at this point.
Ok I have it fixed. I just reflashed the clockworkmod recovery back to the phone via ODIN and then I was able to load the new nightly. I'm going to use my phone like this for a few days then I might try out the new ICS leak to see which one works better.
Jack
Abheetha Athukorala
