slow charging issue please help!
joecobb
Ok so I got the LG Viper about a month ago and two to three weeks after I got it I noticed that almost every time I would plug it in it a notification saying slow charging pops up with a symbol in the notification bar. Can anyone please help me with this? Thanks.
If you are using USB Port too charge then you will see that happen. Really would use a wall charger. using the USB Port too charge has caused alot of problems with battery overheating issues as well. worse using car charger and using google nav. together will really cause future charing the battery issues as time goes on.
I am using a wall charger. I plugged it into my laptop once then a few days later I noticed the slow charging icon and ever since then I have noticed that symbol when ever I plug my phone in.
I believe thats a firmware issue. and I believe thats why the battery overheating and charging is causing alot of replacement issues of the device
I had this phone for about a week and no matter which source I used to charge it took forever as in several hours.
I had this problem recently with my phone. After several days of the problem persisting I looked up some solutions and it was suggested to clean the port and whatever cable was being used. I used a bit of rubbing alcohol and a tooth brush, only just barely dipped and the extra knocked off. That helped only marginally at first, but about a week later the problem went away.
Annuji202
