Smart Switch from Note 4
That would be great, I agree.
Outside of the app, there are 2 options available for you in the event of a hard reset, if you do the backups ahead of time:
  • You can use Samsung Cloud (if you have less than 15Gb of apps/data). (On VZW you have to do a bit of voodoo to get the app to show up.)
  • You can use Samsung Smart Switch from a PC. I use if for backups for my Galaxy phones all the time. I would recommend doing this anyway for backups, even if you use other methods.
Good luck.
I will have to figure out how to back my n7 up to my computer. Thanks
rosannejoy555
