So frustrated with the Thunderbolt
OK thanks for the replies, the battery life was better today, but I did use it less as well.
I have started using a BT widget, but really i shouldn't have to turn off the BT, then back on for the pairing to happen 2011 Kia Optima SX with BT / NAV and zero issues with 2 M Droids. I have removed the device and re-added in the car .. permissions in phone (but maybe not phonebook - will double check) to always allow to pair.
The task manager I will uninstall, that loaded from the M D1 when activating.
I did choose another stock ringtone (standard one) and it's better but too generic, but testing for now.
I just wish I loved the phone right now, but will give it a few more days (before 14).
Thank you all, it has been helpful! I have installed Juice Defender and uninstalled Adv. task killer. So I am trying to have an open mind today and give it a chance. I may yet adjust other settings, but I want to enjoy this phone.
Yea, just give it a few more days. If it's not doing it for you, just return it. If you don't care for 4G, check out the Incredible 2.
Well I exchanged the TB for another (took 2 hours at the store) but so far, this phone really seems to be loaded a bit different than the other phone (both were brand new) but still have some concern/trouble with the bluetooth connectivity.
Both find each other, paired but the call (dialed from car) won't actually connect. This is a new car and not breaking new technology but honestly I am so frustrated but had to go into work so I don't have time to play with it more now.
Maybe since I have power cycled both units (car and phone) when I go to leave, MAYBE it will pair/work correctly?
Assuming your new TB fixes the BT and ringtone volume issues you had I would also highly recommend getting the OEM 2750mAh extended battery & cover. ;)
Volume (ring tone) unverified yet as I ran out of time to really test that with incoming calls.
BT, still seems to be an issue - will test in our VW when it comes back from the airport to see if phone or my car or combo.
Battery, considering it.
Thanks!
i love my bolt but am having signal issues. I tried the #228 and verizon said they can't program my phone. I have one bar when my wife has 3. Does anyone know if the new verizon fix will solve this. I have phone info installed and set to CDMA auto PRL. I really don't want to get rid of this phone.
How are your actual calls going?
-Frank
Thanks!
Are you turning your phone's volume up when you are in your homescreen (volume rocker up until it says its as loud as it gets)
Also: Menu>Settings>Sounds>Volume... make sure thats where you'd like it as well.
Frank,
around town and home decent, anytime i go into any store(lowes, walmart, etc) I have zero signal and calls are awful.
Update, I did the flash and other than losing everything (apps and such) ... so far this seems to be working, but I am noticing more 1X data vs. 4 or 3 (could be network in the area of work) but no BT pairing issues (so far...).
** apparently there is the 4G outage so my 1x shouldn't be related to my device, just bad timing!
Ishimwe
