So my Android Google and volume is going Crazy and i don't know why and i dont know how to fix it
  • Start date Start date
A
Android Central Question
As I look at my phone all of a suden my Google will go off by it self and my volume to on my Android.
Welcome to Android Central! Does this only happen when headphones are plugged in? If you're using headphones that are designed specifically designed for iPhones, that can cause odd behavior like this, because iPhone headphone jacks are configured differently. If it happens even without headphones plugged in, then there could be debris stuck in the jack that's causing false signals -- use a can of compressed air to blow out the jack, and a toothpick to root around.
KidColoringPage
