Soak Test Invite Time
Ok, update just finished downloading. I'm holding off until I get some more charge into the battery. I'd like to take a quick roll call of everybody who's installed it, and if there are any issues? More interested in hearing from those who haven't rooted their phone, or returned it back to stock first.
Haven't noticed any issues so far, seems to be running as well as it did before.
The motoroot one touch app works after soak upgrade. No issues.
Sent from my DROID MAXX
Was your phone rooted with motoroot before the update? If so did you uninstall SuperSU and tap the Unroot button on motoroot before applying the update?
Does the recent apps menu now reliably bring up the recent apps? Or do you still need to press it two or three times for it to be updated?
Sent from my DROID MAXX via Tapatalk 4.
Seems to be working, didn't really notice the issue before though.
This was driving me nuts before. The problem appears to be gone since applying the update this morning.
Sent from my Droid Maxx
For anyone having issues trying to activate their 50GB Google drive, turn off your Wi-Fi and use the cellular connection. I tried for almost an hour every 10-15 min or so to activate it, and kept getting "can't access server". I turned off Wi-Fi, went outside, made sure I had a good 4G signal, and bang...went through first try. Don't know if it needs to see it coming across the Verizon network or not, but it worked first try...
Where do you find the option to activate the 50GB Google drive. I just launch Drive and it(drive) comes up without an option to activate 50GB of space.....
Does anyone know how to get the 50 gb with an existing Google Drive account?
wobblefix
