Solution: How to PERMANENTLY Remove Knox
Hi there. I"m a total newbie to Android coming from being a Blackberry gal.
I mistakenly added knox, unaware is was a suction app(one that sticks and won't let go)
I was able to use ccleaner to remove Knox, but for the life of me, I cannot remove 6 unwanted files. I've tried nobloat and ccleaner, and the files just won't budge. I've tried Ghost Commander as well and nothing.
Any other suggestions? I had excess/useless files on my phone. I'm OCD, so it really bugs me.
Thanks in advance.
I have a Samsung Galaxy Note 5.
I have figured out how to delete MyKnox from your Samsung, permanently. I work for a wireless carrier in Canada. I did have MyKnox downloaded, but honestly had no use for it. I could not "uninstall" from the Knox settings, and I honestly refused to download another app or do anything to my phone simply because I wanted it removed. I contacted Samsung chat support, and they were also completely useless. Here's how you do it kids...
1.) Go to this website https://my.samsungknox.com/en-US/#/login
2.) Sign in with the information that you used to sign up. If you forgot your username and password, it's incredibly easy to have those sent to you.. assuming you have access to the email you used.
3.) Delete the phone from the account.
4.) Click on settings and delete account.
5.) After having done this, I no longer have MyKnox on my Samsung S7 Edge
No need for rooting, or other apps to remove it and no backing up to factory reset. Hope this helps.
TOOLS
