[Solved] Bluetooth draining battery despite being turned off
Tj Goldstein
10
Hi, Google did an update a few days ago and since then, Bluetooth has been draining my battery despite not being turned on. My overnight drain, while sleeping, has gone from around 10-12% to 45%.
I have turned down screen resolution, deactivated any battery draining apps and a few other minor changes but when looking at battery usage.. Bluetooth is at the top at 85-93%.. this is impossible because it hasn't been turned on for the past 72 hours.
I don't even have the wifi/mobile data turned on unless I need it.. I am very conservative with my phone usage.
Any help someone could provide would be great.
Thankyou.
Hiya, yes it is.. it's gone from about 65% .. when I actually was using it 3 days ago to 85-95% when not in use and turned off. The only thing that has changed is a Google update.
The Bluetooth is showing up as 88.9% while the next one, Firefox, is at 1.29%. Unfortunately, I am unable to do a force stop as it doesn't give me that option. I might have to go into the program itself and disable it or force stop it that way?
Hmm, it's not showing up on either list. When I go into phone settings and choose Bluetooth, it's clearly showed as being off. Not sure what to do now.
When you go into settings>apps>3 dots upper right corner tap>tap system apps
Clear cache and Data under storage there and force stop it Screenshot_20200211-182032.jpeg
Hi,I somehow managed to clear the data cache but not via your steps.. I ended up just pressing random buttons until I got to two seperate ones.. apps and system apps. I cleared the cache and data for both and now, everything is back to normal. Bluetooth no longer shows up as being turned on and it isn't draining the battery anymore. My overnight drain was only 8% and that was with the mobile data accidentally left on. I honestly couldn't tell you the steps I took to clear the data cache but I got there..lol. Thanks so much for your help, I really appreciate it. Have a great day.
Glad you found where it was , your welcome
Every pho e have them in different settings .
Pickle240
