Question [SOLVED] BT Connection sound
Bali Sa
3
Hey,
I have a Samsung A52 S 5G and have the following problem.
When I start up my car I keep getting a notification (sound) of connectivity bleutooth on my phone. I would like to turn this off but can't find how.
I do not want to turn off the notification sound completely. I only have this when I get into my car.
Its an old citroen C5 with an aftermarked bluetooth system. My phone shows the app as Apps2Car.
Thx.
Solution
Hey, thank you all for your ideas.
I found it, only this needed to be turned on, see attachment (its in Dutch, i am from Belgium).
Simple.
Problem solved.
Thx.
Welcome to Android Central! Go to Settings>Apps, select Apps2Car, and then Notifications. Show us what you see in a screenshot.
Welcome to Android Central forums. I found these instructions, let us know if they work for you.
Gemini says.
To turn off Bluetooth audio on a Samsung Galaxy A52, you can go to Settings and turn off Bluetooth. [1, 2]
Steps [1, 3]
  1. Swipe down from the top of the screen
  2. Select the Settings icon
  3. Select Connections
  4. Select the Bluetooth switch to turn it off
You can also turn off Bluetooth by swiping down from the Notification bar and selecting the Bluetooth icon. [1]
You can also watch this video to learn how to turn off Bluetooth file transferring on a Galaxy phone:
Reactions: Laura Knotek
Simple.
Problem solved.
Thx.
Solution
Haris18
