[SOLVED]Phone gets stuck on the HTC bootscreen or bootloops
Re: Phone gets stuck on the HTC bootscreen or bootloops
You mean it wont boot at all?
not at all. just sits there now with the led blinking at me. hope its just a low battery warning :/
Pull the battery for a few minutes then plug it in to the wall charger for a while
Tell me what did it do after you ran the RUU? did it boot at all to the system ?
i actually unplugged it from my computer and put it on the wall. it stopped the blinking so ill check it in a few minutes and see if it boots up
i didnt see it boot into the system. the RUU said it finished with no errors
Cool Beanz! so your up and running ?
HALLELUJAH!! Now leave it alone!
My GS3 sleeps in the bed and I make my girlfriend sleep on the couch
No joke! I dont plan on doing anything to it anymore haha. Now just to mark this as sloved
LOL it gets easier when you do it a few times. Dont let this discourage you. as long as your phone can boot to the bootloader its repairable
Just remember to Google Google Google and Read Read Read before doing anything and if you dont understand it ask first
Lol i know. Ive rooted my old HTC hero before. That was easy. I cam flash almost anything and everything and easily fix it. Same with the few Samsungs ive done but this e3d...pain in my butt
- - - Updated - - -
Hi! I'm having the same problem but when I try this , drop box says it can't find the page. Is it possible to have the file emailed to me? Thanks for your time :)
One more try download this http://db.tt/pxuH2E2G put on your sdcard boot into the bootloader , it should parse the zip and ask if you want to update select yes and pray it works...lol
Yeah its since been removed .Its best you not use that anyway it might not be for your version. What is happening and did it get this way and what have you did to resolve it?
it is bootlooped how can sb go to settings and "about phone" you *****!!!!!
You ran the RUU and its looping?
Sorry to re-open this thread but I am having a similar issue that is not solved.
I have an unrooted Hboot 1.50 Locked with S-ON, 2.08.651.2.
My phone gets to HTC logo and then reboots over and over.
I can get into the bootloader and into fastboot.
Through fastboot I ran RUU 2.08.651.2 exe which was successful (according to windows gui).
However my phone still bootloops even after the supposed successful flash back to stock.
Aguswibowo
