- Dec 28, 2011
- 8,348
- 2,594
- 0
Does this void the warranty? I'm all about DIY, but make sure you don't back yourself into the corner.
Plus, this is supposedly a "temporary" fix.
The internal serial wouldn't match the box and might cause issues for somebody but the store probably returns opened items if you say its defective.
Hm, I have a C60 as well, but there are no hardware issues with mine, only software glitches on the launcher screen.
I bought mine from Sams and it is a C60. I don't see any of the issues being discussed, if I understand what I am looking for. The glass around the top edge is flush and I don't see any issues with the display. Am I safe or just waiting for a failure in the near future?
Probably fine. I'm sure there are a few good ones in there.![]()
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Around the top... check the left side of the bezel. That's the only place I've seen the raised lip, aka screen lift, personally.I bought mine from Sams and it is a C60. I don't see any of the issues being discussed, if I understand what I am looking for. The glass around the top edge is flush and I don't see any issues with the display. Am I safe or just waiting for a failure in the near future?
I hope I'll find that golden egg soon. I'll be even happier!Probably fine. I'm sure there are a few good ones in there.![]()
Reporting in again, I received my replacement from the Play Store today, it's a C70, and there is no creaking sound when pressing on the right bezel (an issue with my old one), but the screen is lifted a tiny amount - and by that I mean less than .5mm, so small I would not have noticed if I wasn't looking for it, so I'm happy with what I got and won't return this one. The new C70 batch seems to be a good one.
