Anyone else notice that every so often the watch gets hot and drains battery until a reboot?
Had couple times in last 2 weeks. I even disabled GPS and same issue.
Got the latest OS on too.
I too have had this battery drain problem with my Sony smartwatch 3 since upgrading my Samsung S5 to Lollipop about a week ago.
I tried many suggestions over the last couple of days but the following appears to have fixed the problem for me:
After your smartwatch has completed charging unplug it and immediately do a restart of your smartwatch.
I did this for the first time this morning at 9am and now (at 8pm) my smartwatch 3 has 79% battery.
I found this on the web last night and I think it was a Sony tech guys advise.
I guess doing the restart after unplugging kills whatever the bad thing is that is causing this problem.
Yeah, a restart does seem to solve it.
TBH, I've restarted only when I've noticed the drain, so maybe restarting after unplugging is something to try.
Yes, the suggested workaround I found specifically said to do the restart immediately after unplugging the smartwatch3 after charging. I've done this a few times now and the discharge problem has not occurred.
Before finding this solution one of the first things I tried was a re-start and it didn't fix it so doing it immediately after charging appears to be the critical point.
Sorry to report that after about 4 charges using this work-around I've had a failure.
My Sony smartwatch3 had been running for about 24 hours and was at 50% charge. I went to my local pub for a couple of hours and checked my watch to find it was at 2% (so lost 50% in 2 hours). I had been charging at around 50% previously so maybe going below that level was the problem.
Ah. Shame.
I've been doing that for 2 days (and this morning) and it's been OK so far. That's not say it won't happen again though.
Could you explain this a bit further please? I've downloaded Sony PC Companion but am unsure where to go from there. There is nothing about a repair update in the app as far as I can see. Thanks
Open the Sony PC Companion
Click on Support Zone
Click the start button under Accessories software update
Wait for the preparing software update to finish
Click on SmartWatch 3, and click next
Connect your SW3, and its going to say that your system is up to date (most likely) and if your experience problems reinstall software.
Click yes and when its finish it'll tell you to unplug it.
Power it off and charge it for 4 hrs.
It took me 3 tries but my watch works as it was intended to now, so just be patient and redo it if it starts to drain again after a few days or weeks.
