Sony Xperia Z3 Magnector X cable (magnetic charger) my new purchase.
I received my deff adapters as well. I only opened one, but the magnet is strong enough to hang the phone from. However, it is susceptible to twisting motions. If recommend using a micro usb cable that flexes easily worth it so that moving the phone doesn't place much force on the connector.
I received the two I ordered....they were only $7 each but they work perfectly....seems to charge faster than the Micro-USB charger
I just received both the adapter and the cord and love both of them! bye bye flappy flaps!
Im also feeling like the phone is charging faster and the magnet is very strong..no complaints!
Are the connectors on the Z1 & Z2 positioned/compatible with the Z3 Compact? (I'm seeing a ton of magnetic cables and adapters for the Z1/Z2, but not too many for the Z3C). :-\
They are the same. Z3 is not mentioned on some as it's a new phone.
It's the same, the one I got was meant for the Z1/Z2 but it works on my Z3
i have generic magnetic charger. it charges fine. the only problem is whenever i am using my phone while charging, and the charger accidentally gets disconnected, my phone returns to home sreen. this is particularly annying when you are playing a game and the game exits. Does this happen to your magnetic charger too?
I bought the magnetic dock charger [Sony not generic] and frankly I was appauled by how bad it was, basically doesn't work at all unless you spend ages messing arround with your phone. No experience with the cable, but I wouldn't recommend the dock at all. It seems like a hit and miss option at best...
Sent from my D6603 using Tapatalk
Patric2204
