Sound file problem
IMANUT46
2,909
8
38
When you go to FILES /AUDIO and test the sound files, after you test the 1st on list, and it plays, the next 1 below starts playing automatically. Is that normal, and if not, how can I fix it. Thanks
I checked and encountered the same thing as you did when using the Google Files app. I did not see a way to turn off auto-play in the the three dots, or the player controls (screen bottom).
That seems to be the way it was designed. You can either long press it or use the 3 dots to open with another player.
Try Total Commander. That will play one track at a time.
Thanks. It's not really a serious problem, but I thought I had an incorrect setting. I'll keep your suggestion if it becomes a problem. Thanks again.
rosannejoy555
