Sound problems since update
rojer
Hello guys,
since the new Android update I have issues with the sound of my pixel 7 pro.
I can listen to music/yt over bluetooth wireless headphones without problems. After disconnecting the headphones there is no sound on YouTube/Reddit/Prime/Netflix but if I play still on Spotify. If I hold my ear right next to the lower end speaker I can hear sound very silently.
After restarting sound works like intended.
Anybody had the issue and found a solution?
Thanks
Welcome to AC!
Try what has been mentioned above if still happening then go to settings to reset network this will delete Bluetooth devices and saved WiFi passwords
Welcome to Android Central! I'm not seeing/hearing that on my Pixel 7 Pro, at least not with YouTube.
I'm sure you checked this already, but just in case -- when you disconnect the earbuds, are you checking the media volume to make sure it's still turned up? The phone will remember what your main speaker volume was set to before you connected the earbuds, so if it had been turned all the way down, then it'll still be all the way down when you disconnect the buds (regardless of how high you had set the volume through the buds).
easeasea
