Sound recording problems
anon(94115)
Banned
Nov 29, 2010
5,697
511
Ok I had this in another post, and I know that at least one other is having the same problems. I figured I would move it to a new post in case someone has the issue.
Since the new kernels came out yesterday, the voice recorder and sound recording on the video recorder do not work for me.
Here is what I have done:
full wipe, installed "stock" froyo, then installed sc 2.9.2 (up until this point sound recording works), then applied any one of the updated kernels. Once they are applied, the recording goes out.
I have done this about 4-5 times so far today. Each time i cleared all the caches and did a data wipe.
No sure where to go from there...
Go into Voodoo Sound Control and check the box marked Original Source for audio input
There's a thread on this issue over at xda, I'll see if I can find the posts for you
Reactions: H2o
Just tested and Im having the same issue,flashed the new voodoo kernal plus the update and have no sound with the video ,not sure if the kernal did that thou because I dont use the camera all that often for videos. *shrugs
*yep that worked for me..all is well again Thanks!!
hiltsy855
