Sound stopped working!
F0REVERY0UNG-
125
So I just updated Netflix, Plume, and HD Widgets and now my sound is no longer working. It just started doing this a few minuets ago.
I now see that the problem is the Netflix update.
Is anyone else having this problem since the update?
Try plugging headphones in. If there is no sound, something is very wrong. You should also go to Settings---> Sound---> Volumes and check to see if the sound settings didn't glitch up.
I'm not sure about this problem, but try downloading SoundAbout. It might get the sound working with Netflix.
Ashok Dharshan
