Source for OEM S4 battery cover?
gjp83
3
so by trying to force my OEM battery cover back over the zerolemon battery (the supposed OEM sized one) my battery cover is now warped and one of the clips will not catch. this has left some play in the way my battery cover fits, so I'm looking for an OEM replacement.
all of the stuff on amazon and eBay appear to be cheap Chinese knock offs. I've tried searching elsewhere with no real luck...just all aftermarket stuff.
who sells original black Samsung pieces?
cheers.
thanks, but like all of the ones I've seen on amazon that's another Chinese aftermarket piece. I am only looking for an original Samsung item.
You could also try reaching directly to Samsung support. Their OEM backs may be produced in China though so you may not be able to get around that.
from my Sony XTZ via Tapatalk IV
sejawkk
