Speaker sound quality
garyray
Active member
Apr 2, 2011
28
I've been considering the G Tablet for a couple weeks now & will probably get it now that it is on sale today.
Just wanted to get some feed back on the quality of the speakers. I'm sure they are not the best but I'd like to be able to use it to listen to music when I shower.
Are they decent enough to hear across a room with the shower running?
HTC EVO 4g with Fresh
I wouldn't count on it. I've had sporadic experiences with the speakers. Though no problem at all if they are hooked up to external speakers or headphones.
I have no issue, these things are LOUD for a tablet. Quality seems fine, no cracking or hissing or any of the like.
i noticed that the right side speaker is louder than the left side. Does anyone have the same issue?
It is supposed to be here today. I'm excited. I'll test it out to see if I can hear it in the shower first chance I get.
It actually sounds pretty decent. I had no problem hearing it over the shower. I gonna have to find an equalizer because it didn't sound like perfect but it is def loud enough to hear.
Bad idea to shower with your tablet in the same room. The moisture and steam isn't going to have any positive effects on the tab or other electronic devices.
I'll keep that in mind. Normally I wouldn't do it but 16ft ceilings & the door never being closed keeps the moisture buildup at a minimum. I never see condensation on the mirror.
kimlien
