Speed Dial entires not saving
scubabob34
10
Coming from a Motorola Droid Turbo -- so far, it's not been too daunting to move to the V30...
However - for some reason, I'm not able to get the speed dial entries to "stick". I'll add a few, then go out of the phone app, then come back in, and the entries have disappeared! :(
Any insight would be welcomed...thanks!!
Bob
ok - I take it by the lack of responses to my question, that either:
1. No one else is having this issue, or
2. No one else uses speed-dialing
Are people just using the quick contact feature of the floating bar???
Thanks - Bob
Thanks - Bob
I'm not even sure what you mean by speed dialing.
1) I "star" the contacts I want to be on the top of my contacts list.
2) Also, I add a widget on my home screen for each contact I call/text frequently.
NT -
Thanks for your ideas.
By "speed dialing", go to phone, choose setting (the 3 dots in the upper right), choose Speed Dial, and then you can add contact for 2-99 (1 is set for vm). Then when you press that number on the dial pad, it will automatically populate with the "saved" contact...at least that's how it's supposed to work. I put a couple in, and it works until you back out of the phone app - kinda like there should be a save button -- but I can't see one! :(
NT -
ARNZIT
