Spotify draining battery
I've checked the play store and I also deleted then reinstalled spotify on my phone 3 or 4 times to see it that would fix the problem
Thanks
mreeveshp
Also double check in Samsung gear app , anything to adjust with settings for Spotify ?
I've checked everything I could think of but I really don't know what to change
Can you tell me what it says for spotify in gear app what can you tweak there ? I have to find my charger for my watch and test this out later but be quicker if you can tell me what options are there .
I can't really find anything to tweak in the wear app except if I want notifications or not. And if I go into apps and click spotify it just shows me this...
Ok , I'll have to charge my watch later and try this out myself.
Thank you for all the help you have given me so far, it means a lot that you are taking so much timr. I thought more would chime in. I'm also still trying to figure out how to setup my beats and watch to work together but I'm using Google for that.
Thanks
mreeveshp
Thanks
mreeveshp
Your welcome , I thought more would also chime in as I don't use watches that much but will try help you with this .
omertasociey
