Sprint 5.1.1 Update Notification sound issues
rockyjay
98
Not sure if any one else has run into this and found a solution.
After Today's update, My phone does not make a sound with Text Messages( Stock app) or Gmail App. They appear on screen, just no sound. All other notifications work fine. I went into settings for both apps and selected a sound, which gave a test, but just don't work when a notification is received.
Also did a reboot.
Any help is appreciated.
After an update like this I usually do a full factory reset and start from scratch. I know it's a pain in the neck , but it usually works out any kinks.
Also did a reboot.
Do a wipe cache partition in Recovery Mode and see if it gets better, if not, then I'm sorry to tell you but you will need to do a factory reset.
Also did a reboot.
Sometimes the notification sound can accidentally be turned off. To check it, just click the volume button and hit the gear icon.
dreaming of electric sheep
Mine is working fine with all notifications.
Posted on my Galaxy S6 edge🔪(S is for Super) via the Android Central App
DannaOgle83
