Sprint Note 3: Battery life
Ricewar
I just bought my phone a month ago. Up until yesterday my battery has been awesome. Now all of a sudden it's dying really fast. Just typing this I've lost 3%!
Re: Battery life
It seems to be ever since the KitKat update that the battery life isn't as good. I just got mine a week ago so I can't compare how it was with Jellybean. The phone updated as soon as I got it.
Re: Battery life
Welcome to Android Central :)
Could you post screenshots of your battery stats? If anything weird stands out it should be an easy fix
Sent from my Galaxy S4 running SlimKat 4.4.2
Re: Battery life
Welcome to Android Central. Verizon still has the Note3 on JellyBean and battery life is pretty good. Have you tried removing the battery for 30 seconds...I read in these forums that it tends to bring back better battery life. Not exactly sure though.
Re: Battery life
As UJ95X said, post your battery stats, I have experienced the same awesome battery life under both JB and KK, I'm sure someone can help identify your problem if you supply more information
As moonover posted, this is starting to be a valid complaint of the kit kat update if that is what you are running. And as other posters suggested, post screen shots of your battery stats. There might be a quick fix.
Palm Treo line > BlackBerry line > Samsung Galaxy S line > NOW the awesome & powerful Samsung Galaxy Note 3! 😆📱😆
My battery has actually gotten even better since kit kat update.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
My battery life got pretty bad. Not sure how to post a screen shot on here. But after only 4 hrs I'm at 81% battery life and it says android system is using 30 % of the battery
Here it is
Sent from my SM-N900P using AC Forums mobile app
I always have it set to sleep after 2 minutes. If that's what your askin
No. I mean out of the four hours the phone was on, how long was the screen on?
This is what Kitkat has done to my Note 3
I've had my note 3 now for a few days. Honestly I wasn't as blown away as I had hoped by battery life. Sure it's not bad, maybe it's because I have been on it so much. At any rate I love the phone. Might even get the 10k mah battery just because I want to see how long it will go.
Sent from my SM-N900P using Tapatalk
😲 they sell that?
I've had my note 3 since November. I run the heck out of it and the battery lasted all day until KitKat. Now the battery lasts just a few hours. Gets hot, have removed the battery, what else to do? Something is running that I can't see, can't close. There is a definite negative difference since the update. :(
Jokerman
