Sprint's Body Glove protective cover for the Evo 4G
the shiny parts are gonna get scratched to hell i bet. bleh
...i also just bought the seidio so maybe i'm being biased ha
either way, it would only cost me like 20 bucks at the sprint store with the premier discount...damn ive spent a lot of money on this phone already(when i dont even have it yet!)
lmao same here! haha
yep, me too, i already bought two car chargers, 2 seidio cases, 1 zagg shield, and I'm about to buy a universal car mount on amazon.
I don't think it looks ugly at all, it looks something the Predator would use if he had a phone! But I am gonna look at it first before buying it obviously.
i'm at seidio case, 2 oem batteries and 2 hdmi cables. luckily i already have a ton of chargers from my current pre.
btw i really like how plain the seidio case is. that was one of the selling points to me.
I wanted to get this, but I bet it won't fit on if you have a shield of some sort on the phone. I got a similar case for my Pre and it wouldn't fit over my invisibleshield.
Thats a really good point. does anyone know if the shack will be getting them? i wanna use that 20 gift card
i like that it looks like it doesn't add bulk. i never had a body case for any of my phones but i will consider it if it comes in hot pink only.
Mine seemed tight to put on. Im thinking about returning it too, but I just dont trust the gel covers.
This case looked really ugly in person. The back looks like it was finished by a 5th or 6th grader. I really like the gel covers Sprint sells, go tit for 11 plus tax with SP discount.
I like the case, but putting it on and taking it off is is very difficult. The top part seems to be just a little small to fit. It seems to be very tight. In the video it seems to go on and off very easily. I wonder if I just got one thats mold was just off. Do you think I should just go back to Sprint and exchange for another one. The case is really nice and fits well in the HTC leather case Sprint is selling. I was thinking of ordering the Seidio Surface II case, but I am not sure it will be any better than the Body Glove.
It is on now, but do you think I should just exchange for another Body Glove that might fit better?
I bought the $14 silicon cover from Sprint ($10 for Premier customers) and it's pretty nice, not too sticky and fits fairly well.
So it really is that difficult to install and to remove? It really did look easy in the video. None my local Sprint stores have that cover yet. I was thinking of ordering it, but if this thing is a pain to install and remove, I'd rather try one first at the store before actually buying it. My main concern is just the camera.
i have this case with an invisible shield on the front. works and fits great. never really liked cases but had to get one for my evo b/c i drop every phone i ever have all the time. now i probably won't drop it once but if i do, i'm overly concerned. 25% off from sprint for being premier customer is always a good thing as well...
Have you taken it off again just to see how hard it is?
its tight, but it came off. you have to be carefull kinda feels like it you just pry it off the top part might break gotta go around the phone a little at a time. there is a latch on the bottom right you can stick a flat head screwdriver in and turn it to get it started then just be careful but it does come off with out a hitch
Really dislike this case and stopped using it within about an hour. The thin plastic strip on the front near the volume rocker isn't secure at all and completely gives as soon as you grab the phone. It's a pretty poorly designed case and I replaced it with another case immediately.
mattellis99
