Sticky screen and lack of response when browsing, high battery discharge.
Camchan
My tab s is now over two years old. Recently it has started to get unresponsive after about 10 minutes use. For example it takes ages to load Internet pages and when you select a link it again takes a long time to load. It also seems the screen is less responsive so if you select the return or home button at the bottom of the screen it takes a while to respond. Similarly the keyboard can have a delayed response to touching a character.
The only thing that seems to help is to re starting it.
Any thoughts as to why this is happening?
Finally my battery is slow to charge and then discharges very quickly when i really only use it for browsing. It also gets hot under the camera. Does this mean I need a new battery?
Mfrepulge
