still no visual voicemail love?
I Installed the voice Google, and the only thing I like about is that I can erase individual voicemails. I don't like the message transcribing into text, that's just ridiculous. Is there a way to change that? I also dont like getting a text message every time I get a voicemail. Help ;)
Well, best advice I can give is ignore the transcript. You can turn of the texts in the settings
Sent from my Transformer
also, when got a text message, go SMS would not notify me, instead, Google voicce would...that's so inconvenient, I just uninstalled Google voice, another useless app
You just need to get it set up right. All the settings are there, believe me
Well,there was one setting that said 'do not disturb ' , but that just sent all my calls to voicemail
I got my voicemail just the way I want it now, but when I text someone, the reply text always goes to Google voice and I no longer get notifications on go SMS :/
Lol, you'll get it down sooner or later. That setting is in there somewhere too.
im on google voice settings, under the voicemail & text app, but i cant find something where i can disable synching my default text app and the google voice..
are you using your Sprint number as your GV number?
No you don't have to. Explains why your texts are routing the way they are.
kutty7
