Stock Firmware
Ok, sounds easy enough I'll try as soon as I get home from school. Only have one class today so I should be back early. After this I can do the OTA update of 4.3 that should come out soon right? Thanks :)
Shudder.
Sent from my Hyperdriven Dev Edition Vzw SCH-I545 with KT kernel using Tapatalk 4
Well yeah if you enjoy being rooted and your custom setup is butter, I'm with you there. But the OP wasn't having a very good time with it, and to each his own.
I think I found the solution to what I was asking in my other thread, just asking to be sure.
I am rooted and on stock firmware. I reset the flash counter but it was still at 1. Could I flash stock firmware so it deletes the custom recovery, and then reset the flash counter so it stays at 0?
I think it was at 1 because I still have TWRP
Just redo the process you did the 1st time when you ran it and it said 0.
Restore your nandroid, run TA, if it says 0 plug it into your Pc and continue with the Odin process.
I did it. Counter still at 1, binary still custom.
Edit: Nevermind, forgot to run TA again. It's at 0 now and binary is official. Thanks :)
One last thing, is there anyway to check flash counts without root? So I can see if it stayed at 0 after unrooting.
Under system settings ->more->about device->status, scroll all the way down and it'll say official.
I believe that's correct.
And if the counter was at one it wouldn't say official right? Thanks, now unrooted and on stock firmware. Did it during my computer engineering class XD
