Stock vs 3rd Party Launcher
Do any of the third party launchers include ways to edit the quick settings in the notification pull down?
Or is there a way to do this from stock?
Sent from my XT1080 using Tapatalk 2
Trying to get my hands on themer but still 50,000 people in front of me
I just downloaded Nova simply to remove the google search bar.
I was determined to use the stock rom on the Maxx, but this was also something I wanted to be able to do. I've been a fan of Nova for quite a while now, so it wasn't hard for me to jump straight back to it.
This isn't a definitive answer, but I've only seen the ability to customize the pull down settings in custom ROMs.
Sent from a Droid Maxx.
I use Nova but I'm always looking for something new. Stock launcher is useless.
Like Optimus Prune said, the only way to actually edit the default android quick settings is via roms. However, there are apps that might be a good alternative for you. Mappz Quick Settings, or AntTek Quick Settings.
https://forums.androidcentral.com/e...ls?id=com.studio.quicksettings&token=ChfNlZVC
https://forums.androidcentral.com/e...ls?id=com.anttek.quicksettings&token=YrDWVb2v
I actually use Mappz and it's been good for me.
I don't have experience with AntTek, but although it seems similar, I see people in the reviews complaining about it.
Thanks optimum and optimus.... I'll take a look at those apps...
noroldie
