Storage card/battery drain?
I'm on my second V20 all apps updated. And the battery last probably 2 to 3 hours. I've wiped the phone. I've cleared app cache under app settings.
My storage card is almost full though.
Any other suggestions.
The SD card will make no discernible difference in battery life. You have something else going on. Have you looked at the battery stats to see what is using the battery?
Probably a silly question, but what happens if you take the SD card out?
Do you have the same problems with lag and battery drain?
Probably a bad microSD. If you just bought the phone brand new, give it 1-2 weeks for the battery and OS to optimize. You'll see improvement afterwards.
AS1890
