Storage space is running out
Still no luck.
Hi I've been having the same problem and before when I had this problem I had to delete my play store and download the newest version and it worked but I candy do it on this phone. But get on utube and look up what your phone is doing there a video that tells you some awesome things you can do. I haven't done it yet cuz I have to get a few things but I will be soon hope you find it and it works good luck:)
Well, I had this problem once. My storage issues were caused by an app called Apps 2 SD, which transfers apps to your SD card if you have root. One option I enabled from the app is the App Installation storage option and I set it to my SD card. That caused my phone to have the Storage is running out problem.
gulkhile
