Strange problem with Nexus 4
colbazzo
Hi everybody
I want to expose my problem, which I can't solve in any way.
I have a Nexus 4 from the other day.
Virtually every 30 seconds appears at the bottom of the display a little black rectangle in which there is written "Sending ..." and when this happens, the display lights.
Point out that the phone has a standard Stock ROM 4.2.1.
I did restore the phone's settings and it did not solve anything.
I also re-flash from scratch the Factory Image 4.2.1, but the problem remained.
I searched far and wide on Google, but could not find anything about it.
I hope you can help me.
Thank you.
Fabrizio.
Please take a screen shot and show us.
Also you may want to consider exchanging it for a new one before it's too late.
Hi everybody
Thank you.
Fabrizio.
Try restoring it and disable wifi and sim card. Continue setting it up and disable sending any information to google or recieving and then slowly continue setting up your phonr. When the problem arises then the thing that you setup last is doing it.
Hi.
I think I have solved it!
I remove the SIM which was inside and I put another one from another operator and it works straight without that annoying Black Rectangle saying "Sending..."
I feel relieved, but may depend on what then?
Hi.
dunno lol. I was just shooting in the dark back there. I don't even have that much experience with SIM card, haven't had a single phone with it. Well I can't remove the SIM card or something. Dunno.
