Strange WiFi issue with LMY48M
m1a1mg
15
I've had 5 GHz issues with my Nexus 6 since I first got it. For some reason it will connect, but there is no throughput. I solved this by only connecting to 2.4. Now with LMY48M, when I select WiFi frequency band and 2.4 GHz only, it does the opposite. It will only connect to 5 GHz. So bizarre. I've even done a complete restore.
Most of prob is password encryption (WPA/WPA2 etc AES/TPSK) then wireless channel.
Sent from my Nexus 6 using Tapatalk
same thing for me. cannot connect to any wifi, security or not after upgrading to LMY48M
does rebooting the phone temporarily fix it?
I believe it does. If doesn't help try clean cache partition if still same issue than reset phone.
I´m having the same problem. After a few hours the phone gets disconnected from any WiFi and dont connect anymore trough WiFi. Only after rebooting it.
I was wondering if it was just me. Same problem, here. Also getting brownish banding in photos since the update, aswell.
Rukhshan
