stuck on reboot screen after odin root what i doo???????
  • Start date Start date
A
AC Question
i rooted my phone and it worked for 24 hours then it shutted down i try to reboot it im stuck on reboot screen there nothing to do.. it says downloading do not turn off target please help i spent my whole day on this..
I FOUND THIS TIP: but didnt know what to do its embiguous
Method 2 – Enter Recovery Mode using ADB on Windows
Step 1 – Make sure USB drivers / ADB drivers for Galaxy A5 have been installed and ADB is configured on your computer.
Step 2 – Connect your Galaxy A5 to your PC with a USB cable and install ADB drivers (if needed).
Step 3 – Navigate to android-sdk-windows\platform-tools directory and open Command Prompt (Shift + Right-click anywhere in the folder > Open Command Prompt).
Step 4 – Type in the following command and press Enter.
adb reboot recovery
Step 5 – Your Galaxy A5 will turn OFF and then boot into the Recovery Mode. Navigate up and down using the volume keys and select with the Power button.
There a few ways to do it but if the phone and pc don't see each other no way can we move forward. Just a crazy Ida but hold down power key for 30 seconds and release
araelbenjie
