Stuck on Starting RSD mode 2.
tfx1
Flashed Build HWI69 for US Retail on a Canadian wifi MZ604 xoom..tired of
waiting for 3.1 update.
adb reboot bootloader
fastboot oem unlock
Xoom will then reboot into bootloader screen
fastboot flash boot boot.img
fastboot flash system system.img
fastboot flash recovery recovery.img
fastboot flash userdata userdata.img
fastboot erase cache
fastboot oem lock
fastboot reboot
It is stuck on Starting RSD mode 2.
I can not get it to fastboot protocol...and device does not turn off.
Any solutions?
Press volume up & power so the Xoom reboots.
After it reboots, right when the red logo shows up press the volume down button, it should toggle between the different modes the Xoom can enter. Hopefully you can get it back in to fastboot or recovery. You'll need to update your Xoom's bootloader/hboot to make it work with a different version.
kiki2025
