Sudden really bad battery drain
Runnin_it
146
4
Has anyone seen this? My 3VO has been a boss until now. I noticed the phone got a bit warmer yesterday than usual, but I chalked it up to the unusually large amount of push emails I was getting; long story, work, reunion, and death in the family...
Anyway, today my battery has been draining like crazy...2hrs 27m, and my phone is down from a full charge to 62% with minimal use...as in 2-3 texts, a couple of emails...and nothing else.
Anyone else seen this?
When was the last time you rebooted? May have background processes running that are not needed
Sent from my Carrier Pigeon using Tapatalk.
Reactions: Runnin_it
Actually I rebooted last night before I put it on the charger. The back felt a little hot, so I wanted to make sure there were no extra processes running while it was charging.
It dropped to 47% about 45 minutes after I posted. It's on the charger now (second time today). As much as I hate to, I am going to fully charge it and do a hard reset. Will let you guys know if it helps...
Did you download any new apps?? You may have a rouge app if this just started.. Download watchdog and it will notify you if something is going crazy..
What's your battery status/info say? Most of the time when I have some crazy drop it all makes sense. Just this weekend I noticed I was down to 60% after only a few hours of being awake. Then I saw that Slacker Radio was keeping the phone awake from the minute I took it off the charger. Forced stop and all was good the rest of the day.
I am currently experiencing the same problem. When I looked at the battery info, a significant amount of battery was used by "Mediaserver."
I had heard that this can be caused by a corrupt media file. I downloaded the pictures and videos I have taken to my laptop and then erased the contents of the DCIM folder. Hopefully that will fix my problems.
I will report back.
Whats your up and awake time in the battery stats? If your up time is anywhere near the awake time you have a problem with an app.
Up time is 10:20:43
Awake time is 09:51:10
I just took it off the charger 2 minutes ago. I am doing a power button>restart now.
In the time since my last post, I have
1. Restarted the phone
2. Changed the skin
3. Downloaded and installed Watchdog
Battery has dropped from 100% to 95%
I'm starting to think the battery has gone south...and I have only had this phone a week.
I have isolated a few causes of fast battery drain...the biggest one is the Facebook for htc app. Unsync that if you haven't. That alone might be the issue.
Well, I took the phone into Sprint yesterday. The guy tested the battery. The tester said the battery was good, but the charge was low...the battery was at about 65% at the time...he replaced it since there was obviously a problem. After 3hours off the charger, the phone is at 91%. :-)
Thanks everyone for your suggestions!
im not haveing tha problem bt my EVO 3D wont keep charge and this is my 3rd one ......i put it on the charger when it gets to 100% it looses power as if it was on stand by so when i wake up the green light is on as if it was charged bt battery is at 92 or 65 or 73 percent and i know its not the batt or the plug there both ar brand new jus got them i havent downloaded any apps or root...... any help will do
After your phone hits 100% off of a charge the phone runs off of the battery again. Seems stupid but thats what HTC did. Pending on your area do you have good service? This morning at my house I woke up to a green light. But the phone only had 98% battery life. So it just might be the timing.
I had that issue too in the last few days...suddenly it's horrible. I lost almost 25% of battery life in the matter of a hour with sending 4 texts and leaving it idle.
Even now it's been off off the charger since 7AM, sent approximately 10 texts and I'm at 52%. I thought my battery issues were gone(see battery life thread) but apparently they're back. I might bring it back to Sprint and have them test it.
I noticed a similar issue for the first time today. I went to a new gym I had not been to b4 and had a very weak 3g signal. I was running slacker and my phone heated up to 109 degrees and my battery started draining faster than I've seen it b4. Soon as I got home it cooled back down and the battery was normal again. In my experience the weak 3g signal is what's causing these battery issues...
spoutti
