Supcase Case for Mate20Pro
SaifulIslam
13
How many of you guys that are using supcase with your mate20pro? Did you remove the built-in screenprotector that comes together with your case?
I have never used cases other than UAG. But i would say its better to remove in order for fingerprint to work.
Did you used any protection for you screen? The built in screen protector that comes with supcase feels cheap.
What screen protector? Mine only had the back case. Canadian product?
I thought I read somewhere someone mentioned a plastic film on the front. My wife's Honor 6x came with that but very noticeable nothing like that on my Mate that's visible.
Mine didn't come with any screen protector. Just a clear case.
If that case comes with a tempered glass with the front case then itll ruin your in display fps.
only plastic screen protector works with it
daisuk
