Super Battery Saver is stuck on
  • Start date Start date
A
Android Central Question
My Nokia 8.3 5G recently updated to Android 12, and I just activated "Super Battery Saver" mode. However, afterwards, the mode is stuck on, yet the toggle switch for it is still in the off position, yet says "on" in the text. When I tap the toggle again, it asks if I want to turn the mode on, and if I say yes, it goes through the motions of telling me what power-saving measures it's activating, then continues to be in super battery saver mode, with the switch still saying on but being in the off position. Also, if I select the option to turn SBS off at 50% charge, then back out of that menu, then go back into it, that option switches itself off. Additionally, for some reason, the square button (app switcher) in my three-button navigation is missing entirely. I'm not sure why one simple option would break so many things all at once. I've restarted my phone a couple times, and nothing has changed.
Just FYI for anyone experiencing this problem, I found a solution without going into Safe Mode (not sure it would've helped tbh). Just go to Settings > Battery > Schedule (below Super Battery Saver), then set an end time for the next minute or two. Once the clock ticks over to the set time, it should turn off Super Battery Saver.
Great thanks for sharing your fix
Winnie
