Super SU Installation Failed. How do I fix it?
The only thing that worked for me was running Sunshine to get S off. Then I ran Kingroot (you can google the app) to get temp root and installed SuperSU.
After that I removed Kingroot and with S off and SuperSU it works fine on 5.0.1.
pls share the link to Sunshine and kingroot. can't find dem on playstore
To get the kingroot.com you can either root through the android app or through the windows program.
The other application i have never heard of.
If all you want to do is root the phone Do this.
1- Unlock the bootloader through HTCDev https://www.htcdev.com/
2-Flash a custom recovery TWRP recommended https://twrp.me/Devices/
3- Flash SuperSU with TWRP recovery https://download.chainfire.eu/696/SuperSU/UPDATE-SuperSU-v2.46.zip
REMEMBER When unlocking the bootloader your data and internal storage will be wiped. Backup all your Pics music files and use htc backup to backup your system setup
Andacar
