Superuser Help
thank guys i try on my PC when i get home, i will give an update once i try
Yeah I meant rename the recovery file itself, not the backup file, on the CPU
The recovery file is what you're going to try to flash manually via adb.
If that doesn't work rerooting is the way to go, and might actually just be easier to do in the first place if you feel like it.
NP. liquid smooth 1.25 is not a nightly, it's a stable release.
Highly recommend either liquid, patient zero m1, or aokp (any recent build) for a starter rom - lots of features and fast.
alright that worked and i am back up and running with liquid smooth it is fast i want to thank all the guys on here you guys are awesome and patient, thanks again
Right on....make sure you check out liquid control :)
nirmalafoundation
