Support Group for those switching from WebOS (palm pre) to Nexus S 4g
HERE IS HOW TO DO IT ON THE EVO - Different phone, same exact concept.
FYI - The reason this mod is not popular with android devices is, it makes it so the compass in your phone no longer works. The magnets under the battery door, which hold the phone to the touchstone, disable the compass inside android phones. The Pre/Pixi do not have a compass so this was a non-issue.
"I want JustType/Universal Search. It takes way to many presses to get anything done"
If you use the google search bar it acts like universal search. it can search almost anything if you edit the options.
If you want to save yourself some screen real estate, just long press the menu button (looks like 4 horizontal lines). It pulls up your keyboard and when you type it automatically does a universal search.
Reactions: skinneejay
I'm pretty sure there was a lot of discussion about this on precentral & the magnet is in the touchstone, not in the coil. Maybe the steel/iron plate in the door causes problems with the compass?
The touchstone back on the Pre has magnets in it. Four of them I believe.
So I guess any hack for other phones would involve putting magnets in it.
Not sure, I just know it broke the compass in android phones. Not sure the who what when where or why. Speaking of Precentral ..... Power sharing: Evo 4G modded for Touchstone compatibility [video] | PreCentral.net | The #1 Palm Pre and Pixi Community
"While the magnets do interfere with the Evo 4G?s built-in compass (not a problem, of course, for compass-less Pres and Pixis) "
Understood, but it doesn't do first initial/last name searches (jsmith for john smith) so it takes more typing, then I have to select the person I want and then the action to take. In WebOs, if I type "JS" and I only know one person with those initials, I am presented immediately with all the actions that can be taken on that contact. I'm sure I'll adjust - it just takes longer to bring up contacts and that's an issue when I'm driving.
I try to use voice dialing now whenever possible -- that is a feature that I love. Unfortunately my wife spells her name in a non-standard way so when I try to call her she's not on the list. I had to switch to a shortcut for he instead (I love the shortcuts to contacts -- very functional and efficient).
I see that you are a moderator. Can you approve my post from this morning so that it will show up?
-darren
As I sit and spin in my chair the compass works fine. I bet it won't work on the touchstone because that's got a big magnet in it.
Interestingly, the little metal studs in the touchstone charging back are marked with a plus sign (+) on one side, but they don't attract ferrous metal objects so I doubt they are magnets. The touchstone, on the other hand, has a substantial magnet in it.
-darren
-darren
was this difficult to do? i'm not very handy! if send you my back can you do it for $$?? :D
I posted the link that KSmithinNy posted along with a link to an iFixit teardown of the Nexus S earlier this morning, but it hasn't shown up yet
From reading the EVO how to and looking at the teardown, I'm guessing you can peel the coil from the Pre touchstone back and then stick to the inside of the Nexus back same as the EVO, then you have to run wires from the touchstone contacts to somewhere on the phone's mainboard. I think the best spot would be to the USB port. The wires coming in are exposed there, though they are very small. If you connected there (as opposed to the battery terminals) you'd go through the phone's charging circuit.
I'm interested in seeing the details of your mod, also darrenf. I'm hoping to do this in the next week or two based on your success.
My reply was for skinneejay. It was a suggestion for skineejay to save screen space by deleting the google bar and using the shortcut to get to it.
his post - my reply
-darren
I am a moderator but all 4 of your posts are available. There is no approval system on his site.
This is confusing... I had this popup with my post this morning and one I just tried now with a link to the ifixit teardown of the Nexus S:
"ramk13
Thank you for posting! Your post will not be visible until a moderator has approved it for posting."
The only thing I can think of that would have made it require moderation is the link I pasted. The odd thing is that you posted the same link (easy to come across by googling 'touchstone mod') later. Maybe it's because Darren and I don't have many posts? Sorry to be semi off topic, but this limitation is holding back the touchstone discussion for the Nexus and several people are interested in it.
No that is definitely strange. I will see if I can figure out what might be going on. There are some wonky things going on in the spam world so new measures might have been put in place. Will BRB
Thanks guys. Since it's fixed I'll go ahead and retype my first post (but just in case I'll copy it to the clipboard :) ).
I was indeed inspired by the iFixIt teardown and this touchstone mod for the Epic 4G:
Samsung Epic 4g Inductive Charger
The Epic has more room inside, but the Nexus S has the advantage of a charging port positioned at the bottom of the phone. Here are the steps I performed along with caveats for anyone else who might want to try.
Move the touchstone charging back coil into the Nexus S back
  • First, I tore apart a Pre inductive charging back. I removed the plastic film covering the inner working, then removed all the pieces (4 studs, coil and circuit) and pressed them into the adhesive on the plastic I had just removed.
  • Next, I removed the NFC antenna from the back of the Nexus S. This might not be strictly required but I didn't like the idea of a large antenna coil sandwiched between a set of induction coils pushing 5V+. At this point I have no use for NFC so it was no loss for me.
  • After a small amount of trimming, I found the location on the inside of the Nexus S back where I wanted to position the coil from the pre charging back. I positioned this twice before finding a location that I liked. I kept putting the back onto a touchstone to see where it would align relative to the table.
  • I pressed the plastic cover on the charging coil into the back of the Nexus S. I didn't add any glue. The original adhesive was very good and in the finished product this is sandwiched in very tightly so it won't move.
Connect wires to the USB port in the Nexus S
  • Not knowing exactly what gauge wire to use, I tore apart a USB cable and removed about 6" of the red and black conductors. You can probably get by with a lot smaller wire. I chose this wire in part because it was stranded. Now I don't have to worry as much about pulling a solder joint loose by flexing the wire when I take the back off in the future.
  • Disassembling the Nexus S is a dream compared to the Pre. As shown in the instructions on iFixIt, remove six screws around the outside of the rear plastic shroud and it comes right off. There are no tamper-evident stickers.
  • One thing not covered on iFixIt is that to get the rear plastic shroud apart from the screen, you need to pry the trim ring from around the outside of the phone, specifically the two long edges, so that you can see and release the tiny plastic clips that hold the two halves together. If anyone is trying this, I strongly suggest that you outfit yourself with a set of plastic/nylon cellphone disassembly tools first to avoid marring the phone. You can get a set cheaply from DX here if you are the patient sort. :)
  • Now I was looking at the guts of the phone. This is comprised of a single PC board and several floppy bits (camera, earpiece, etc) attached by small cables. All of this will come out together after removing three screws located in the top third of the phone and disconnecting two ribbon cables, one in the top left of the board and one at the bottom left, IIRC. The only trouble I had was the earpiece which is installed with adhesive so I had to pry more than I was comfortable with but it eventually came out.
  • At this point I could see the USB port at the bottom of the phone and the wires connecting it to the PC board. I needed to find the 5V+ supply wire. Knowing that the outside two pins are 5V+ and signal ground, I checked continuity between the shield and each outside pin. The one that didn't ring out was the 5V+ supply. THIS NEXT PART WAS THE REALLY HARD BIT I tinned up one end of my red wire and soldered it to the 5V+ supply line coming off the back of the USB port. Had I messed this up I could have been looking for a new phone, but since it worked I knew I was home free.
  • I then stripped about 1/4" off the black wire, tinned it, tinned one side of the USB connector shield and soldered them together. This is a very solid solder joint and very easy to make.
  • Next I looked at where the plastic of the phone would mate to the PC board and routed the wires such that they might be sandwiched tightly but wouldn't increase the thickness of the finished product. This was pretty easy and there were several ways I could have routed them. I chose to come up into the battery bay via a little hole that Samsung had pre-drilled in the battery bay surround (take out the battery and you can see it). This was far easier than in the Epic mod in the Instructables link above. I reassembled everything as part of this process, checking tolerances as I went.
Finishing the construction
  • The last and easiest step is to trim the wires to length, tin up the wire ends and contacts on the inductive charging back, and solder them together. To discover the polarity of the contacts, I set the back onto a touchstone and measured DC voltage across the contacts. You can just look at my picture. :)
  • As I installed the back on the phone, I routed the wires so that they wouldn't cross each other or cross the circuit on the charging coil (the thickest part of the back at this point). I used some Scotch tape to hold them in place. If I did it again I would make the red wire shorter so that it would more easily nest under the black, but I made it work.
I wish I had taken more photos and if I ever have to take the phone apart or mod another one, I'll be sure to take more photos and post them. By looking at the photos on iFixIt and Instructables you will get a pretty good idea of what's in store.
Note: since the back of the Nexus S and the ring around the touchstone are both smooth, it doesn't grip as tightly as the Pre. If you are charging on your desk this is no problem at all. If you use a touchstone in your car, you will want to apply strips of electrical tape or vinyl stickers down the sides of the back to give the mating surface more friction.
Good luck luck to anyone else who endeavors to do this. I would be glad to answer questions if you still have any.
-darren
Hoping that the problem was fixed, I retyped my post but still got the moderation message. Fortunately, I copied it to the clipboard this time. :) Since I was able to post a photo before, I'm going to presume that URLs are the culprit so I'm including those as images rather than embedded links. I'm sorry to the reader that you would need to type the URL -- I don't know another solution.
I was indeed inspired by the iFixIt teardown and by this touchstone mod for the Epic 4G:
  • One thing not covered on iFixIt is that to get the rear plastic shroud apart from the screen, you need to pry the trim ring from around the outside of the phone, specifically the two long edges, so that you can see and release the tiny plastic clips that hold the two halves together. If anyone is trying this, I strongly suggest that you outfit yourself with a set of plastic/nylon cellphone disassembly tools first to avoid marring the phone. You can get a set cheaply from DX if you are the patient sort. :)
-darren
It's still not working. I retyped my post from this morning only to be presented with the moderator approval message. Fortunately I thought to save the article to the clipboard so I posted it again, this time replacing all URLs with images. That failed too.
I don't know what else to try. Having typed this twice, I would really like to have it post. Mods, can you shed any light on why these little posts go through without incident but the large ones are held for moderation?
-darren
Good luck luck to anyone else who endeavors to do this. I would be glad to answer questions if you still have any..
-darren
unhappy74
