Surprise! Android 3.2 update for Revue
Mine just updated. The entire system runs a helluva lot faster. Chrome doesn't lag any more. Haven't tried YouTube yet.
Sent from my PG86100 using Android Central Forums
"Nick040489 wrote: Actually you don't have to reset the device. That's more of a pain. You can follow the same method that they have used for the Galaxy Nexus and the Motorola Xoom
1. From your Revue, head into Settings>Apps>All.
2. Search for Google Services Framework.
3. Once found, tap on it and choose “Force stop.”
4. Then choose “Clear data.”
5. Back out of Apps to your About page in Settings and check for the System update.
I know it works because I tried rebooting my Revue and checking for updates numerous times but to no avail. I decided to try that method and as soon as I did it my Revue found the update. Just a little bit easier than a factory reset."
Got this from gtvhacker, worked on second try!
I'm posting this reply on my Logitech Revue running 3.2 having received the firmware update automagically at around 4.30 this morning.
It is significantly faster in every respect. Dare I say, may actually be working like it should have when it was released nearly two years ago.
I am located in Seattle, and did not clear my system framework, nor did I perform a hard reset, or a soft reset for that matter. People - Relax. It's just a firmware update. Leave your system alone, and let it update according to the roll-out schedule.
/e
Noticed the boot up was different on Review, then read there was an update checked the system and saw it was version 3.2. Updated automatically. Hope the Google movies show up in Google Play soon.
3. Once found, tap on it and choose ?Force stop.?
4. Then choose ?Clear data.?
I tried this and did not get the update!
I just checked and one has the 3.2 update.
I have 2 Revues and the newer of the 2 has already got the update on its own.
Mine came sometime Saturday. I haven't had a chance to mess with it though to see if it's faster or any other differences.
Checked Friday... nothing. Went away for the weekend and when I returned home on Monday I noticed both of my boxes were updated while I was gone.
I had been out of the loop on this subject. Today it all of a sudden told me there was an update and wanted to reboot and install it So I said yes. I then came straight here to find out what it was
I just checked my Revue and it appears I have the 3.2 update.
I tested Netflix and so far so good. No more errors with Netflix. Movies stream with no issues so far. I'll test more tomorrow. Hopefully this update fixed the Netflix error that everyone gets.
Sent from my ASUS Transformer Pad TF300T using Tapatalk
Can't believe I just came across this....need to check my Google tv tonight!
Going to have to fire mine up. I plan on getting the vizio co star when it drops. Hopefully its done better than the revue.
Red_Nexus
