SwiftKey Not work, help please!
Punkidish
46
I downloaded swiftkey and did all the steps. Maybe im doing something wrong, i dunno. The box is checked. Any help would be appreciated.
Go to your phone’s Main Menu and tap the SwiftKey icon. If SwiftKey is not enabled you will be asked to enable it, and then be taken to Text Settings. Make sure SwiftKey is checked. Then go to any text field on your phone, press and hold to bring up the menu and choose Select Input Method. From there, choose SwiftKey. You are now using SwiftKey.
After you enable it. Press and hold in any text input field and you should get a prompt for input method. Then select the keyboard you want.
BrainOne
