Swipe to accept incoming phone call
  • Start date Start date
A
AC Question
Hi, I have a NGM FORWARD ENDURANCE which is running KitKat 4.4.2 and I'm basically very happy with its performance.
However, I have one difficulty and wonder if anyone has a remedy?
When I receive an incoming phone call, and attempt to answer by touching, holding and dragging the Icon toward me, nine times out of ten, I miss the call.....
I just find it difficult to complete the operation satisfactorily.
My question is..Is there an alternative way to answer an incoming call?
I've looked in the Settings > Accessibility but there does not appear to be an option to change this function - only an option to end a call by pressing the Home key.
I really would appreciate any solution.......
Not familiar with that phone but do you have an option for enabling single tap? Samsung has it on some of their phones, allows you to tap for calls, alarms, and other things instead of swiping.
Hi L0n3N1nja,
Thanks for your response - much appreciated... I can't see any option within the settings, to allow tapping instead of swiping. Is it possible that there is an app. which would allow an alternative to swiping?
KidColoringPage
