Switch between iPhone 4s and skyrocket
I have the new skyrocket after upgrading from the 3gs.
Also got the other half a 4s upgrade.
Having used both I think the 4S is a much better phone to use unless you have hours and hours to spend setting it up.
Its not that the skyrocket can't do everything the 4s can and much more, but rather trying to figure out what it can do and how to do it.......
Would gladly trade back to a 4s, but didn't get it done in the 14 day grace period.......
I'm also on my second skyrocket as the first one got so hot from the battery discharge they switched it out on the spot...:-\
I'll admit that it is tedious to setting up your home screen to getting it the way you want, but just add shortcuts instead of widgets. Before I flashed my phone with MIUI, I had my center screen with clock and weather widgets, one screen with "driving" items (a music widget and shortcut icons to google maps and navigation), one screen with a Plume widget (so I can send tweets fast) and frequently used app shortcuts, and one screen with shopping app shortcuts and games.
cinemacritic
