Sync headphones volume with phone, possible?
neil74
1,288
12
38
Should say sync headphone and v30 volume!
Has anybody managed to get headphone and device volume synced on the V30?
On Bluetooth headphones the volume operates independently and I would prefer to sync them up like they are on the pixel or can be on the S8.
On most phones, the headphone volume is reduced as soon as you plug the headphones in (to keep from damaging your hearing - and trust me, a single blast of loud noise in an earbud can cause incurable loss of hearing). There's not much you can (or should) do about that.
Bluetooth volume isn't independently settable - it's set by the media volume - which is also what you're probably using the headphones for.
So bottom line - you can't do what you want (and you shouldn't).
I think you misunderstand? My issue is that the volume is independent I.e. volume on headphones does not control volume on the phone, you can adjust both.
How it works on the pixel (how it works out of the box) and also on Samsung via media volume sync.
glastek16
