Syncing S-Memo with Evernote
Hi, try the following which worked for me:
Select S Memo App
Menu
Export
-select S Note file (.snb) OPTION
- select All or just the memos you want to export.
- click DONE
New screen is displayed providing options for you to Select Google Docs, Evernote or ' My Files'
Good luck!
I just synched all my S-Notes with evernote. But in Evernote, while they are there, they are all "attachments" to the note and won't open!
Some how I managed to get it right.
Go to S Memo
Tap bottom left corner.Tap"export"
->All the S Memos will box at top.Select individually or select all.->tap "done"
Pop up appears -> Select "Evernote"
screen will load "S Evernote" page. Select the folder required and tap "done"(at top right hand corner)
all the noted will be imported.
It does work after some agonising trials:)
Hi, my synching from Snote to Everynote works find. But if I add a new note in Evernote, that does not sync with Snote. I cannot find that new note added in Evernote in Snotes. please help
I have the exact same problem. All my SMemos from S4 sync with Evernote fine but when I access Evernote on OnePlus3, they just show up as 'attachments' and won't open!
Adekanmbi
