System (system/bin/logd) battery drain?
Michaelw81
Active member
May 27, 2015
38
Hey guys, this appears to be draining 70% of my battery, it's an absolute joke. The only fixes I've found, involve rooting my device, which I don't want to. Has anyone had this fault and managed to sort it?
Thanka
According to this there's a way to disable the LOGD without root. I assume you did factory reset? I also assume you changed the GPS settings. From my experience apps not optimized for marshmallow are to blame. My battery performance is now pre-marshmallow performance. The system isn't granular enough to be of much help. Too much stuff in there you can't see unless the phone is rooted.
GPS settings, as in just turn off location? I'll have a look at that link thanks. I've not factory reset yet, as to be fair, I'm sick of doing it. Every couple of months another reason pops up, and I have to do one. I can't wait to get rid of this phone now. Great camera, but the battery issue just does my head in
GPS is a big drain on power. If you are not actively using GPS, just turn it off.
GPS - anything but High accuracy. That might be using too much battery. I have it set to "Battery Saving"
Settings->Location->Mode
Unfortunately factory reset makes a significant improvement. I used LG Backup & restore, didn't reinstall or rely just on Google restore.
Heathererry
